Hi everybody,
now that the Beomaster is fixed, I started work on my also newly arrived BG 5005. After opening it I found that the rails the tonearm uses for the horizontal movement came loose, so I fixed that. Now, the problem that I can't fix is that the tonearm is very loose, it just wobbles around actually and is a lot lower than the indicator arm (which is perfectly tight). I'm not able to bring it any higher, as the screw that should be tightened for that purpose always manages to get away from my screwdriver (sounds weird, I know...) And I also have the feeling a simple tightening of said screw isn't gonna solve that problem.
Another problem is that once I push play, everything starts as it should (apart from the stylus that is sometimes so low I have to lift it on the record manually, and I guess I'll need a retipping soon like that...). The stylus then just stays in place and plays the same part of the LP over and over. I can't even move the tonearm using the buttons, and I also can't lift it with the buttons (which might very well be because the loose fit of the tonearm).
But when I start the record by pushing the 'turn' button, it acts just like when pushing play, but now I can at least move the tonearm pushing the directional buttons (bar the 'lift' option, of course). Still, the same section is played infinitely. The 'stop' command works as it should in both 'modes'.
Anyone having an educated guess?
