Posted August 1, 2024 at 16:17 GMT
Solved.
R 121 was burnt and replaced. Measured value was 24 kΩ, should have been 68 Ω. I could not find a 0.14 W resistor, but replaced it with 0.25 W. The alternative would have been 0.125W. Should I continue hunting for a68 Ω 0.14 W resistor, or is a slightly larger specified one OK?
One of the caps was shorted, C107. The other three — C103, 106 and 108 measured around 80-90 μF and slightly high ESR out of cirquit. I replaced all four of them.
I took your advice and acquired replacement ICs, but decided to test the player without replacing them. Analog sound was back again:) Would it be wise to change the ICs even if the player is working fine for now?
