Beogram 400x projects
The motor amplifier output at 45 RPM speed selection will also go over 6 VRMS without distortion. It's frequency is a little higher than the service manual as well though. The manual asks for 57.3 Hz and I am measuring 57.96 Hz.
The next step is to start buttoning down the Beogram so I can do the rest of the adjustments and get it to the point I can really evaluate the performance of the new cartridge mount from Beolover. I am hoping to reach that step sometime this weekend.
I believe I have the platter motor amplifier adjusted to a good starting point now. First I set the control panel speed trimmers to the center position of the trim pots.
Then I adjusted the main board speed trimmers 1VR1 (33 RPM) & 1VR2 (45 RPM) so the motor output (with the appropriate speed selected) frequencies were as close to 42.3 Hz (33 RPM) and 57.3 Hz (45 RPM) as I could get them. Once that was done I readjusted the motor amplifier output signal so it was between 6 VRMS and 6.5 VRMS for both speeds.
The output looks pretty good as measured on my oscilloscope. I will have to recheck the speeds when I get the platter and belt on.
Here is the 45 RPM speed output
Thanks John upping my learning vurve
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Hi John,
Awesome thread!! I scanned the 24V bulb circuit diagram and posted it on my blog:
http://beolover.blogspot.com/2016/01/beogram-4000-alternate-circuit-diagram-2.html
Rudy
That's a nice quality scan, thanks!
I found this picture of the BG4000 control panel 3IL3 & 3IL4 from my first Beogram 4000 unit. It has a slightly different board than my current one but it also has the two lamps in series so they are 12 V lamps. This second BG4000 turntable has the board that can be wired for either the 12 V or 24 V lamps which is what was confusing. But that is the goal of this 400x thread...to collect and show as much information on these great turntables as possible.
Tonight I installed the replacement tracking sensor lamp source I got from Beolover. It is an LED replacement with a built in trimmer resistor for fine tuning the sensitivity of the tracking sensor. I like this integrated replacement as the original trimmer was added on later and hangs off the tonearm transport assembly. This replacement looks cleaner. It is also a drop in replacement so the original can be restored if I want to later.
