Normal 0 false false false MicrosoftInternetExplorer4
I have a Beogram 4004 with a speed related speed issue. This problem came up 3 years ago and I purchased a new belt thinking that was the most like cause. Apparently not. New belt in place and I promptly forgot about this issue.
This 4004 has been my “trouble free” turntable having never once needed an adjustment. (a lot more than I can say about the 4000, 4002, AND 8000)
Playing a standard 33 1/3RPM record is exactly what should be expected.
However when playing a 45RPM LP record, the 4004 slows down mid-play to near stop, playing VERY, VERY slowly. Switching back and forth between 33 1/3 and 45 does little good. Towards the end of the record the 4004 always speeds back up, possibly even playing a bit too fast.
I applied pressure to the record during play to see if the belt slipped, but there was no evidence of that.
Changed the record to a standard 33 1/3 and problem solved…. but (of course) not really.
I am thinking perhaps a bad contact, but I really don’t know, I am guessing blind.
If anyone has experienced anything like this with a 4000 series turntable I’d appreciate a suggestion as to how to address it.
Thanks,
Jeff
