Beogram 4004 never turns off
Thanks for the suggestions in this thread, it solved the problem on my bg4002. I’ll just show you a couple if pictures of the wires in question. On mine it was red, gray and White that were broken.
Hi. I have Same issue being the plater not turning off. I checked these wires are OK and TR1 seems switching fine. There seem to be a residual voltage around 10 to 12 v all over the place in the circuit that causes the motor to vibrate or sometimes rotate resulting in non stop operation of the platter. Also the bulbs light faintly as a result of this voltage. Could this be some sort of grounding issue? SO switch has 0.1 Ohm resistance so it should be OK.
