BEOGRAM 4002 RUN TO FAST
Hi all,
I've bought a second Beogram 4002 Type 5521 in almost MINT condition. Unfortunally the motor run to fast (over 10 seconds per minute). How can i calibrate the speed? All other functions are working good...
Thanks!
Upgrade to silver or gold membership and download the service manual. Page 4-1 describes speed adjustment.
You will need a stroboscopic disc, available to buy or download on the internet.
Strobo discs
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thanks for the quick and helpful answers.
I've already the schematic...
My questions: Is this job easy to do for a non technican? Which strobo disc i have to use in Europe the 50 Hz? Will the strobo disc work with a Maglite Flashlight?
Best Regards
I just use  a desk light plugged into the 50Hz mains. Works OK for me.
Turn the appropriate potentiometer until the speed is correct. Easy!
It is important that the lamp flickers at 50 (100hz) this means a standard tungsten filament lamp should be used. A traditional ballast flo tube would be ok but not modern electronically controlled stuff.
Jow, I use a normal lamp 60 Hz
Retired
Rock and Roll music
Collecting Vinyl
Thanks! I'll try it at the Weekend...
Best Regards
Remember you are 50 Hz
Retired
Rock and Roll music
Collecting Vinyl
Update: It works and it was easy to adjust also for a non technican.
One question about the speed of the stroboscop-disc. There is a 33.33 (33 1/3) and a 45.11 (45). Why is it 45.11 and not exactly 45?
Thanks for the advice.
