Beogram 4002, clack, scratch sound
Hello,
Only when I listen to the Beogram 4002.
Kindest regards
Mats
I will try that, thanks for the suggestions. I will get back to you when I have tried them.
Kindest regards
Mats
No,
Kindest
Mats
Could it be a static discharge from the record/platter/surround?
Has the platter been cleaned with anything other than a soft cloth?
Hello Martin,
How should I clean the platter?
Kindest regards
Mats
Should I only use a soft cloth then, any specific cloth?
Kindest regards
Mats
specific material I meant ;-)
Mats
You don't have to clean the platter now.
It's just that, if the platter was cleaned at some point, its coating may have been damaged.
Many owners, - particularly of the type 59xx decks, wash their platters or use
solvent-based cleaning products to make the platter shiny.
It may look nice, but the coating has then been washed away and the platters static discharging properties will have been ruined.
This will cause problems with static electricity, that charges up on the record from airs friction. In severe cases you can see "lightning"-type sparks from the record to surrounding chassis metal in a dark room.
The platter should not be shiny. Cleaning should only be done with a soft cloth
Great thanks,
I will follow your instructions.
I get back to you later on.
Kindest regards
Mats
In severe cases you can see “lightning”-type sparks from the record to surrounding chassis metal in a dark room.
Please Dillen, be gentle with new members. You don't have to be that" scary, Freddy-len! ;-)
