Hello,
I have only ever owned Technics 1200s (of various marks) - so I am used to simple repairs. ANyway, on a recent digging excursion I received a Beogram 4002 5113 as part of a purchase. Long story short - it needs work and I have it pretty disassembled at the moment.
The tonearm moves with the controls; and the lift/lower button activates the solenoid and plunger, I have lubricated all the parts... the problem is with the arm that the plunger is supposed to push back (thus allowing the tonearm to lower). The arm in question does not move freely... it is stiff and slow and unless I manually push/pull it up and down, the tonearm does not lower.
I read it is supposed to be spring loaded; however, it doesn't feel like it as it doesn't return to it's original location unless I manually move it. There is a spring attached to the adjustable screw at point of the arm that makes contact with the plunger - but I'm not good with mechanics so I'm not sure what I need to do to get this going.
I attached a photo of the arm in question...
Any suggestions would be appreciated.
Thanks a million.
Peace!
