I currently have a 4002 that I picked up some time ago that was not working properly ( arm would not drop), we'll sorted out that problem, changed the belts and the table has been working fine and has been used daily for the past 8 months. The only problem has been with using 45rpm, I never got around to addressing it so I would like to see if I can fix the problem. The problem is as follows, if I place a 45 on the table,the arm sense's that it is a 45 and the speed changes to 45rpm and the arm drops, the speed holds at 45rpm for maybe 20 seconds and then it slows down and then goes up a bit and then down again though it never really achieves 45 rpm again.Does anyone have any insight into where the problem may be?
thanks,john
