I would go with the 20EN and buy records for the other £100 instead. My reasoning would be that the 4002 probably was factory fitted with the naked elliptical for good reasons. But both 20EN and 20CL was made to work great with tangential tracking turntables. Slight misalignment of old turntables might be less of a problem with a more forgiving stylus shape then a fine line.
https://www.sound-smith.com/articles/stylus-shape-information”
”The higher end designs, however, require far more precise alignment than the lower quality shapes, for what should be obvious reasons. It is easier to align a rounded end to a groove than a V shaped end. Alignment issues for both rotating off a vertical imaginary line in the groove looking end on, as well as tilting front to back along the groove become far more critical for proper tracing of the groove. ”
