Alright,
Thanks so much for all your help thus far. I am making progress since I last reported... I started adding a fresh set of RCAs to this 4002. The cartridge that is on it has a broken cantilever; however, I just wanted to test the new RCA cable from the output board by connecting it to a DJ Mixer w/ Headphones (that is fully working for other tables (Technics SL-1200).
I am using this diagram from beolover to assist my testing.
Here are the test results:
1. With no cartridge installed - both R and L channels BUZZ (not hum) super loud. I'm not sure if this is normal behaviour or not. Once the output relay switches on -- buzzzzzzzzz.
2. With the cartridge installed - only the L channel buzzes - the R channel does have a bit of hum (that stops if I touch any piece of metal in the ground path), but would still be listenable (though not enjoyable).
3. If I bridge System Ground (shield) and the Signal Return Ground - no effect in hum.
What are your thoughts... what do you hear on your BeoGram 4002 with no cartridge installed? Is there a crazy ass buzz? Is it silent?
I feel so close (yet so far)...
Thanks for all your help so far!
