I have a Beogram 4002 (5501) never repaired, in good conditions. I live in Brazil and unfortunately no specialists in this equipment, I just have an electronic technician that repair my equipment but, in this case, need some additional support.
Suddenly my turntable presented a strange behavior, when press "start" button it starts to work but stops. If I keep pressing the "start" button it run 33rpm and cartridge move slow (similar when press "<" Key) and if the "start" button is relief the cartridge move slow to other direction (similar when press ">" Key) and in the end it turns off. However, if I keep pressing the "33" button and then press "start" everything works perfectly, including all manual commands; if I relief the "33" button the tonearm goes slow to end position (same behavior mentioned above).
I know the best way would be a fully review in the equipment, but as I told I just have a good electronic technician to repair, but not a beogram specialist.
I really appreciate any comment to help me and my technician to repair my turntable. Thanks in Advance
