Beogram 4000 Tone arm problem
Hi My Beogram 4000 developed a problem when I was removing the stylus last night, the plastic bracket that holds the stylus came away with the stylus. The little connector had two wires attached a blue and a grean one, but I noticed that there are two inside red and possibly a grey one. Can anyone help with this or does anyone know the best way to take this apart without doing more damage. Help most welcome.
Kevin
Just a little update
 I managed at last to get the small wires out of the tone arm and then  to feed them through with great patience again. I am attemting to repair the arm on a temporary basis as the mount will be glued but fragile, this seems possible fitting a stylus which will have to remain on until a replacement tone arm for BG4000 is found.
Kevin
