Beogram 4000 service?
Hello,
from my earlier thread, i think its time i got a good service on my 4000.
I live in South London.
I spoke to B&O and they can have it looked at in the Bexelyheath branch. Anyone have any experience with them?
Are there any other places that anyone would recommend?
Tom
Rex Radio seem to have a good reputation for servicing the older stuff. Their details come up if you "google" them.
Thanks for that. Ill give them a call but they are the opposite side of London to me.
I have heard that AVA services in Surrey might be good. Anyone used them?
On a side note. HAs anyone replaced the capacitors with high quality branded ones and noticed a huge sound difference?
thanks
Tom
There are no electronics in the signal path in your Beogram so the answer
to your last question will be a no.
This guy talks a good talk and has an excellent warranty
Blimey his site reads like one of those emails you get with pages of reasons as to why you should buy product X lol...
However, he really does look like a reasonable chap so definately worth a ring and speaking to him!
I have used AVA in Coulsden & would recommend them. However, 'phone before delivering as he is sometimes out returning repairs.
If belts are required, you need to get them from 'Dillen' as they aren't available from B&O U.K. to the best of my knowledge.
(I have no connection with AVA apart from as a customer.)
What work does your BG4000 need - and where are you based?
Im based near Camberwell, so a careful drive to Coulsden is probably better than heading to Kilburn or Harrow.
I really just want to get it checked out as it was overheating a bit and occasionally making a slight grinding noise on the return of the arm.
If I get it taken in I will most likely get the capacitors all changed as i guess this has never been done in its life.
Its a beautiful turntable and deserves to be treated with respect.
Have you any idea how much they charge at AVA for this kind of work?
It would also be interesting to see if anyone has a view toward the work carried out at an official B&O retailer.
Tom
I suggest that you get a quote first. You may get a nasty shock.
In the case of the 4000, I would say a reasonable adage would be, if it isn't broken, don't fix it! I would get the arm looked at but replacing all the capacitors is probably not necessary, will have no effect on the sound and will be very expensive. To pull it all apart and subject it to attack by soldering iron is more likely, in my view, to cause problems. My 4000 has had the necessary bits fixed and has performed admirably now for the last 10 years or so. Of course get the faulty bit fixed - sounds like a clean and look at the relevant circuit board is needed, but I would strongly suggest leaving it at that.
