Hi all,
After much running in circles I have sort of solved the problem of noise on the power caused by the motor. While changing some connections I accidentally touched the + side of 0C6 to the chassis and the noise went away. It seems the chassis is not actually connected the PSU ground as the motor did not stop turning.I tried connecting + of 0C6 to the chassis via a small electrolytic capacitor, this also killed the noise so that's what I've settled on for now.
I had been going through the detector circuit before the PSU noise was making everything too confusing.
DR seems to be working correctly in isolation. When I disconnect it from the logic board it is high with a record on the platter and low when there isn't one. The strange thing is when it is connected to the green DR cable going to the logic board it goes high momentarily as the arm reaches the edge of the record but the goes low for the rest of the travel. If I stop the travel by pressing the lift button DR goes high and remains so and I can lower the tonearm and play the record.
I have also replace 3IC7 as I ordered a couple a while back , this made no difference.
Onwards and upwards.
Please let me know if anyone has any thoughts
Cheers
Paul
