Beogram 4000 repair
Hi everyone,
We have success!
I replaced the tip31/32 transistors in the motor drive circuit and I now have a turning motor. I have adjusted the motor voltage with my scope but I have some funny blobs on the trace. Could this be my motor capacitors? I have ordered some new ones anyway.
I dismantled the servo motor and added a little lubrication, it's now much quieter.
Just waiting for my belts from Martin and we should be spinning some tunes!
Cheers
Paul
Hi all,
I have received by belts from Martin, many thanks!
Sadly I have to now delve into fixing some logic issues. The Beogram does not see the record on the platter, it does not stop at the 30cm point and just continues to the centre. The light in the arm is on. I can stop the arm and lower it manually. Going through the fault finding in the manual it seems to point to 3IC7 being faulty but the voltage at BS is sort of middle not low or high.
I think I'll be doing some switch cleaning and measuring again.
Ok....before you check 31C7 or do any more work anywhere else check your power supply voltage levels and also the condition of the power supply capacitors....I have been down this road recently and discovered that a lot of the difficulties where due to the power supply capacitors failing under load, replace them first then look again, check my thread "a beogram 4000" and see if there are any similarities
Craig
Thanks Craig, I’ve ordered some capacitors, my power voltages are correct but they don’t look very smooth on the scope. I’ll check out your thread.
Paul
Paul
See link below to the thread as per your request....
Craig
/forum/imported-unmapped/a-beogram-4000
Hi all,
More frustration.....
When I press ON the arm travels out at normal speed to the centre point, hits the end stop and returns but very slowly. If I move the tonearm to the left during the return the servo motor will speed up. If I measure the voltage on the servo motor terminals during the slow return one is 10v and the other 14v. When the arm goes to the centre at normal speed these voltage are 14v and about 2v (I have mislaid my decent meter so these value are a bit rough)
Any ideas?
Paul
I have now changed the 4 power supply capacitors and the AC motor capacitors. The 6v line looks much smoother now but I still have the fuzz on the AC motor as on my scope picture earlier in the thread. The strange operation of the arm has not changed.
What would be really helpful would be an explanation of all the logic abbreviations if anyone has access to such a thing.
Cheers
Paul
Cheers
Paul
Many thanks to Nick for supplying me with the Beogram 4000 training notes, incredibly useful.
With the aid of said document I have solved the slow returning of the carriage. The switch which disconnects the power from the tracking photocells was dirty. Power was going the servo motor control from two systems which probably ended up blowing 1TR28.
I now have a better idea about how the logic works so onwards and upwards.
By using manual control the old girl played a side of a record for the first time in about 35 years! (lifted off too soon but I’ll forgive that for now)
Cheers
Paul
Hi all,
After changing the power supply and motor capacitors I was hoping it would cure the noise on the 6 Volt supply.
Sadly not.
One thing I did discover - if I disconnect the AC motor from the power amp (therefore not running) the noise goes away.
How would the motor be inducing noise?
Paul
