Good morning Jacques,
I've had a look at the chart.. but it's more complicated than what I thought... I should have something to check voltage and understand all the points into the electrical components.. after some tentative and tests I checked that after pushing on ON button, the arm always stopped and start playing from the moment on which the contact touched the red button Login to view image
