Hi Folks!
After many years I am now the proud owner of my first B&O product. Hmm...one problem though...it doesn't work!
Having browsed through the forum I know this topic has been covered several times, but I still can't find the answer I need. Basically the arm doesn't lower. It cues and finds the record and stops at the start. I can also cue in and out manually. If there is no record on the deck it cues to the end and returns to stop. That part is fine, but the arm stays up. Mechanically everything seems free. I can push the solenoid in by hand and the arm will lower, but I don't really want to stand holding the solenoid in while listening to my LPs.
I have no voltage getting to the solenoid. Firstly, can anyone tell me what voltage operates this solenoid? I have traced the circuit back to transistors 0TR4, 1TR10 and 1TR11 that I assume in my basic knowledge operate the solenoid. I have no voltage readings on any of the terminals of these transistors. Can anyone advise where to go from here?
Also, there is a bulb on the underside of the main circuit board that doesn't make sense why it should be there. I haven't seen it light up so I don't know if it's faulty, but could this have anything to do with the problem?
Any help would be appreciated, thanks.
Alex
