any idea where i can get a replacement for this wire drive and instructions on assembly ?
many thanks from another B&O enthusiast
Ronen, Israel
Ronen, Israel
My bet is that the wire hasn't broken, but instead the small hook on the foot of the carriage has broken off.
Fit a screw through the nearby hole from below with a washer and nut on top, and fit the ends of the wire to the excess threading.
It has been shown here in the forum several times. Do a search.
amazing Martin. thanks for this prompt reply. did some searching with the word "wire drive". any suggestion for other search keywords that might work ?
humbly yours
R.
many thanks !
Suggest you try "beogram string" as a search. Common sense really!
