Hello everyone.
The belt came off this Beogram 3000 so I decided to replace it. so far I've demounted the turntable platter and put the new belt on following the Service Manual, all without much trouble, then comes the re-assembling and this rather odd issue comes along;
the record guide (29) as it's called in the Service Manual, just won't fit on the cylinder that goes through middle of the turntable platter, it seems there is a metal ring inside the hole of the record guide that makes it impossible for the cylinder to go through it. Does anyone have any idea what to do? I'm quite lost.
(Update)
New belt works great, but machine is still noisy, suspecting it needs some oil, but if anyone has other ideas too that would be great! Also I'm not really sure where to apply the oil.
Then I got new power cables and phono cables to replace the old ones and I've got kind of an idea what to do, but some clear instructions would be great too!
Thank you!
Pictures below:
Metal ring blocks the cylinder
Spring
Screws
