My Beogram 3000(5228) Started playing tricks on me.
When I press the Lift button, the record begins to spin, accompanied by the illumination of the orange light. However, the tone arm, refuses to move towards the record. This leaves me with no alternative but to unplug the player, as it becomes unresponsive in this state. This 'unplugging' workaround seems to act as a reset, enabling the player to function normally once more when I subsequently press the Lift (Play) button.
This issue first surfaced approximately six months ago, and since then, it has escalated in severity. Regrettably, it has now reached a point where it is nearly impossible for me to play records without resorting to the unplugging and resetting procedure.
In an attempt to address the issue, I undertook some maintenance a few months ago. This included lubricating all relevant components and replacing the motor bearings, belt, and idler wheel. Despite my efforts, the problem persists unabated, and the lubrication and part replacements did not yield the desired solution.
So fellow members, do anyone have a idea what to try next?
