Beogram 3000 (5211) grounding
@Mark-sf
It does not work like that. You need to rotate the counterweight all the way in until it engages in a hole. Than you need to move the ring on the tonearm to the desired stylus pressure. It is in the manual.
As long as the cartridge body (coils) is fine you can simply replace the stylus. The SP-9 was the elliptical version of your SP-7 and is available on the web such as https://www.lpgear.com/product/BOSSP09.html
Hello!
Congratulations on your purchase of the Beogram 3000 turntable! It's great to hear that it's in good condition despite its age.
Regarding the issue with the grounding, it's possible that the previous owner did not properly ground the RCA connectors. You can try connecting a wire from the grounding screw on the back of the turntable to the ground terminal on your amplifier or receiver. This should help eliminate the hum in your speakers.
If this doesn't work, you may want to consider re-installing the DIN connector, which is the original connector type for the Beogram 3000. You can find a replacement DIN connector online or at a local electronics store. Once you have the DIN connector, you can follow the wiring diagram in the turntable's manual to properly ground the turntable.
Regarding the belt replacement, it's always a good idea to replace the belt on a vintage turntable to ensure optimal performance. You can find replacement belts online from various sources, such as Turntable Needles, LP Gear, and Thakker. Make sure to get the correct size belt for your turntable. When replacing the belt, be careful not to damage any other components, and refer to the turntable's manual or online tutorials for guidance.
I hope this helps! Enjoy your Beogram 3000!
Problem solved by changing the RCA connectors with new ones. It seems that the previous owner made some rudimentary connections there...
Anyone know a reliable source for a belt designed for this turntable? I have ordered from two different companies and none of them fit, one has a larger diameter and the other one is wider...
