Play a not critical record and have the tone arm run in the middle.
While playing, push nothing on the Control Panel and Pull The Plug to cut power.
While holding the tone arm, slide the clear plastic force indicator to 1.0 grams.
Set the B&O Gram Balance (Kit came with my MMC4000 cartridge in 1976) on the center of the record and place the stylus in the groove at 1.0 grams. (Saw a MMC4000 cartridge kit box on eBay about $90, no cartridge of course.)
Look to see if the balance teeters level. If not, use a small screwdriver to move the Lead Weight in the Tone Arm in and out. There is a small hole in the back of the tone arm to reach the slotted set screw in the weight. I think there is a small hole in the dust cover too, to reach through and access the set screw. While holding the tone arm protecting the cartridge, you can wiggle the weight loose by grabbing the edges of the small rectangular aluminum plate. Look at the set screw and see how it works. You can adjust it and press the weight back into the tone arm as well.
When your Tone Arm indicator is set to 1.0, and the Balance teeters at 1.0, you are golden.
Now set the sliding Tone Arm Scale to around 1.2 or whatever your cartridge and records need.
Remove everything placed on the record surface or elsewhere, and plug your B&O back into the power outlet.
Gabe
