The fact that it is silent when the mute switch is engaged is indicative of an improper ground configuration. This can happen when cables are replaced. With the table unmuted and the RCA cables disconnected, take the following measurements with an ohm meter:
- Measure between the ground wire and shield of each RCA and you should see an open connection >1Mohm.
- Measure between the ground wire and the ground of the circuit board and should read 0 ohms.
- Remove the cartridge and measure between the ground wire and the copper tang at the end of the tonearm - should read 0 ohms.
If any of the above are not correct, you can get a hum.
