BeoGram 2000
And you have a record on the platter, right ?
The Beogram won't start without a record.
Hi Martin.
Yes, there was a record on the platter (thankfully, otherwise I'd have felt pretty silly!).
It looks like the belt may have stretched as it's not overly tight to the turntable part and this is making it slip off and also kink.
Would it be easier to diagnose if I either supplied some pics or did a Skype call so you could better diagnose it? Hoping it's simple and cheap to fix - have a wedding coming up so buying a new deck is out of the question at the mo! :-)
looking for a belt kit for a BG 1700
