I have purchased a Beogram 2000 (type 5821) which powers up, the buttons all seem to work - the arm moves but the previous owner has removed the DIN connector leaving exposed wires (please see photo)
Is there anyone here who can help please with guidance on the correct way to reconnect the wires to the correct pins on a DIN connector. Thank you in advance for any help you can give me.
7 pin DIN connector on order and I am able to solder but need to be sure I am connecting the wires to the correct Pins.
If it makes any difference I plan to use my "new" Beogram 2000 with a BeoCenter 9500.
The wires are Yellow, Blue, Black, Red with what appears to be a bare metal sheath around it, a White wire with a similar bare wire sheath and then a second Black wire - but it does not have metal inside the plastic?
I really would appreciate any help that anyone could give me please - Thank you,
nick
