Grab under as close to the spindle as possible, not to bend the copper plate.
It's easily distorted.
Use a puller. Grab under as close to the spindle as possible, not to bend the copper plate. It's easily distorted. MartinHi Martin @dillen, hi @vintage-hifi-dude I have almost the same problem. The motor starts bit slow with 32rpm) and runs properly after 10-15 minutes or so. The copper wheel spins approximately 4-5 seconds without any noise when I run it by hand. Do I have to replace the bearings as well? If so I assume I need these bearing (with one collared) - correct? The main issue is to get the copper wheel of the spindle. How do get this of? What kind of puller did you use? Do you have a photo or so? I don't want to destroy or break anything as the rest of the turntable is in a very good state. Thanks in advance for your support.
