Beogram 1800 not setting down at correct point on record
Hi, I have a Beogram 1800 that the tonearm is setting down prior to the record. Is there an adjustment that can be made to make the tonearm set down on the record and not the surface before the record?
Thank you!
Todd
Yes, there is. However, it depends what kind of Beogram 1800 you have. If it is the one from the early 70s, you can look at this post: /forum/imported-unmapped/beogram-1800-68-72#post-2263299
If it is a Beogram 1800 from the 80s, the procedure is this:
Perfect! Thank you so much Filip! I have the 1800 from the '80's. Is there any way to get to it, without taking the top surface plate off (if this is what would need done otherwise)?
Thank you Martin. Sounds like good advice.
