BEOGRAM 1700 problem with SMMC20 Soundsmith cartridge !
Thank you very much for all your kind correspondence  🙂
If I have problems,  I will ask for your generous help again...  !
Maggie
Dear all,
I'm new to this B&O 4002. Need soem guidance / advice form you all.
I have a beogram 4002 but encounter some problem as below:
1) when presss "start" button, the arm will move to the center of the LP and the motor for the arm won't stop (keep running). It will on stop when i press "down/play" Since the arm at center i can't play music, i have to press ">" button to move the arm to the LP to start playing.
2) The worse part is that while playing music, the arm is static , it will not move, thus the song is keep repeating theat the same track...
any ideoa of the problem? anybody have the manual for this 4002?
