I want to change belt on my Beogram 1700 (type 5731) but can't figure out how to remove the turntable platter. It seem as just applying vertical force won't work here (worried I might break something, but either it's stuck or there's some other way to remove it).
The user manual is not helping me here (attached image). I wonder if you would need to remove the plastic 45 rpm adapter that seem to be attached to the platter first?
Anyone with a Beogram 1700 or similar model with the same type of platter w. 45 adapter that could give some advice here?
Thanks!
