The saga continues.
Disappointingly, there is no real difference. Some records still get stuck, others play fine. It can be anywhere on the record but seems to get worse as the arm moves to the centre.
I disassembled the arm, cleaned all 13 ball bearings - 3 on top an 10 below and everything around. I don't recommend this!
I would like to check I have re-assembled the bearing correctly as the manual isn't clear to me.
The attached picture shows the top of the arm mount. You can see the centre spindle is not round (looks like it was done in the factory) so you cannot remove the brass washer under the E clip to totally disassemble the arm. Under the brass washer is a plastic retainer with 3 recesses which hold the 3 top ball bearings. It looks as if the bearings should sit under the plastic piece, which is where I have put them. Can anyone confirm this?
Any other thoughts on why the arm should stick would be appreciated.
