I'm from Australia & am restoring a Beogram 1200 Type 5214 for a friend who's an enthusiast.He bought it from an op shop.Most of it is intact with a seemingly good working motor,however the start mechanism (activated by the black button) is inoperative & may have some parts missing......According to the service manual this is how it's supposed to work:Looking at the unit with bottom cover removed,there is an arm which is swung anticlockwise (when the black start button is pushed) which pulls on another arm called the 'slide bar'.This 'slide bar' engages on a tooth of the 'cam-lifting wheel' , moving it ,causing the wheel to activate a microswitch which makes the motor start up if it was previously stopped. Presumably the 'slide bar ' is held in its place slotted to the chassis on one end & by a return spring & a couple of washers on the other end.
My question is where is the 'slide bar' return spring anchored?Is there supposed to be some sort of guide that holds the 'slide bar' near the 'cam lifting wheel'?...The service manaul does not show any anchoring point.I would appreciate if someone could explain &/or have photos of the part of the 'slide bar' that I'm talking about.
