Beogram 1200 setup
Thanks Andy. That must be the problem!
Fixed!!!  Thanks SO much Andy. The the part that the counter-weight screws on (bolt?) needed to be tightened as it also keeps the tone arm from sliding around on the stylus adjustment rod! Did the balancing with zero grammes and then adding the 2 grammes and it worked like a dream!!
 Yay for Andy and Beoworld!!
I'm so happy you have it sorted, and glad I was of some help.
Enjoy your Beogram😁
Andy T.
I think I have a user manual for the 1200, got it after sending B&O an email and asking for it!
Don't forget to set the speed adjuster to 0 (the dial on the left) when you're not using it for a while; eases the tension on the belt I think.
Pete.
