Hi All,
I'm new to this so please bear with me if I ask a few novice questions. My Dad and I are about to embark on a restoration of a Beogram 1200...I've always loved the design and recall great sound when I was a kid.
I've spent a bit of time reading the existing work many of you have done in this space, so thanks in advance for the knowledge you've already armed me with.
For now, I'd appreciate your insights into a few questions :
1) Is it ok to use sewing machine oil to lubricate bearings, or should I use Kontakt Chemie lub oil 88?
2) What grease should I use on gears, metal arms that move etc? I haven't seen anything specific about what grease to use, like whether it needs to tolerate heat and so on.
3) I'm going to use a donor motor from a defunct 1202 that I was given...the motor spins after the previous owner used sewing machine oil...he never took it apart though. If it's spinning, do I need to still disassemble and regrease? Or even, shouldI skip the 1200 resto and rather try to resuscitate the 1202? The 1202 has a bent tonearm, and I gather this is complex to change over.
4) if the cartridge is gone, can I substitute an SP 10 in this kit?
I'm based in South Africa so there's not much ships out here from the ebay's of the world for spares.
Many thanks in advance for your help!
