OK, so you're reading this and saying to yourselves - what a dumbass 😁 - he still hasn't fixed the motor - it's rotating 20% too slow. In order to get it to rotate at 33rpm, he has to put the selector at 45......
Well, I started doing the math - I hadn't done this math since I was in university 40 years ago. Wheel ratios, and RPM's etc.
It worked out that in order to rotate the platter at 33rpm, the Rubber Idler diameter needs to be 71mm!!!!!
No way. The maximum idler diameter which would physically fit in the BG is 59mm.
So, either I made a royal screw-up with the bearings, or there was something else.
During the calculations, I had assumed that the Brass Pulley diameter is fixed (with a 3% variation), So I went back to the calculations, to solve for a pulley diameter variable which would suit the existing Idler diameter of between 56-59mm.
And I came up with a pulley diameter of 5.6mm.
Then I looked at my own BG1203, which works flawlessly (no surprises there), and I had a double-take. My BG1203 pulley LOOKS fatter than the BG3000 pulley. I pulled out my calipers and measured. Click on the picture to open it fully, and see all the Results.
The BG3000 pulley is THINNER. It probably comes from a country with 60Hz electricity.
My BG1203 was bought in Israel (a 50Hz country) - and has a diameter of 5.6mm on the 33rpm section!
Can anyone in the Americas confirm that their pulley matches the thinner of the 2 pictured below?
And if anyone wants to get rid of a fatter 50Hz pulley (swap for other parts), most appreciative.
Soren, I remember that you made up your own 60Hz pulley - were these dimensions close to what you calculated?
Menahem
