I have a BG3000 - 1973-model radial. Beautiful machine, which I've serviced many of.
But here I have a problem, which I have never seen before.
Common problem - it came in with a non-working motor. My normal procedure is a complete cleaning, oil and shim the motor.
That solves the problem on all the 1202's, 1203's and 3000's, which I've previously done.
I've checked all connections, replaced the diode and capacitor inside the relay, cleaned all contacts.
I disassembled the top and bottom bearings of the motor, removed the old felt discs, put in new felt, didn't help.
But this one - forget it. The motor barely starts rotating, very slowly, and then the slightest pressure from the idler wheel stops the motor.
It's as if it just doesn't have enough juice.
Any ideas?
Is this an issue with the BG1202 / 3000?
If not, does anyone have a spare motor assembly, preferably from a 1203?
Menahem
