BeoGram 1000: alternative RIAA PreAmp ?
Different transistors and diodes were used in production.
Indeed OA81 are found in some versions.
Mexking, I still have your RIAA here, remember.
- And it actually has OA81 fitted.
Component search I have done a quick check for components. There's two challenges that I see:
  1. Some components have values that are not very common any more, e.g.: capacitor 10uF/6.4v, 80uF/25v, 100uF/6.4v, etc.
  2. I have to make sure that the sizes of the components chosen are the same, to make it fit on the original board remake.
Questions (a) Can anyone recommend an online source where components with these 'vintage' values can be found? (b) Are the diode types AO70 & AO81 interchangeable? Or does it depend on the version of the board which one to choose?
here
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Try Mouser Electronics, but you will have to go for radial leaded caps in some cases, looking at the PCB you should be able to fit them. start looking for 80/25 if not there, look for 82/25 and so on just keep it inside the 20%. If you dont find it check with Martin, I know he has some of them if not all. I will go check in my stock I have 80 and 100 axial in stock but dont remember which V
Retired
Rock and Roll music
Collecting Vinyl
Component list
Retired
Rock and Roll music
Collecting Vinyl
the components that make headache are not so critical:
80µF / 25 V  could be replaced with 100µF /25 V
33µF / 64V could be replaced with 47µF / 63V
1,6µF /25V could be replaced with 2,2µF / 25V or to be as near with a 4,7µ / 25V in series with a 2,2µF /25 V resulting in 1,5 µF /25V but not really necessary.
125µF / 16V could be replaced with 100µF /16 V or to be as close as possible get a 100µF /16V with a parallel 22µF /16V
The 80µF and 33µF are used to 'clean' the supply and bias voltages.
The 1,6 µF is for removing the DC offset from the input and output so i would use just a simple 2,2µF. It has no influence to the frequency response of the RIAA preamp.
Also every capacitor for 64V could be replaced with a 63V type
I hope this helps :)
Thnx @Mexking & @ RaMaBo ! Interesting that there are some differences in the values of certain components; between the info I posted in the start of this Thread and the info in the schematics & parts list of Mexking. E.g.
  • Capacitor #22 and 23 = 200uF/25v vs. 80uF/25v
  • Capacitor #49 and 51 = 80uF/25v vs 1.6uF/25v
Is this correct?
There are apparently at least 2 different versions, one with OA81 and one with OA70 fitted. The OA81 has the smaller caps and different transistors fitted, yours and my pic of the PCB are identical, whereas your trace with components pic is different. So you will have to decide which one you want to copy.
@ Martin, I remember the RIAA, the BG 1000 is still going strong playing with my son in CPH together with the BM 1900 you also restored connected now to some Sonos equipment, but let the young ones play around. I would here put a big smiley if I could
Retired
Rock and Roll music
Collecting Vinyl
I think you guys are right, about the two versions.
I also think the 2nd version is 'easier' to rebuild as the values of the capacitors are closer to components available.
There are several, slightly different, versions.
Three of the ones shown here have different transistors, and the last one is an entirely different (earlier) version, mainly seen in 41FV and 42FV.
