B&O 3D Prints
Easy to design.
I use (and still learning) Fusion360. It can be used for free for students and small business.
Fusion360 takes time to learn. It’s from Autodesk and they supply software for professional use.
The final question will be which filament to use. Standard PLA will not be sufficient as it breaks easily.
it looks like 3d printing is a science in itself.
because i work with windows 7 on my pc i do´nt have 3d builder, so I try the free CAD Program : FreeCAD to design .
Confusing, terrible !!
I do`nt understand anything.
I will try  fusion 360 maybe it is not so hard to learn.
Beobuddy wrote:
Easy to design.
+1 for Fusion. I have been using it for about 2 years now. Highly recommend, even if you have to pay for it. Sure beats a Solidworks license at 7-9k / seat.
As for filaments that need to be a little flexible, try PETG. Easily printed (no delamination and always reliably sticks to heated build plates) and has great mechanical properties. Not too stiff like PLA, not too flexible like Nylon, right in between.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
Here's a project I almost forgot about - a wall bracket for BV RL60.2
Never used them myself, they were printed for a friend of mine who I cleaned up a set of RL60.2's for. I did perform a test fit of the bracket and it snapped in perfectly!
The result:
Thanks everyone. It's quite adequate making these parts at home.
Wilfied, i'll take a look at your part tomorrow!
I just finished the sled pulley for the Beogram 4002 i am working on right now. It will be available on my website tomorrow or monday.
Nice weekend everyone :)
My newest addition! The handle for the BG1000 tonearm which is always missing.
Helllo Beobuddy
I already have 3 "patients" with exactly the same problem !!
Even one is hopeless because another tricky leader pin has broken off! see my post:
/forum/beogram/tonarme-chassis-for-beogram-3500-series-5979
Can you please provide these parts to the Beoworld Community?
I am certainly not the only one beside you who has this problem with the tonearm.
thanks a lot and best regards
Just finished an updated version of the tonearm handle for the Beogram 1000 after i learned to use Fusion360.
This one is nearer the original with the rippled surface. After some small adjustments it will be available for download and sale via my website.
Orava wrote:
That in the middle
Like this:
Result::
