Pete,
Thanks for your reply. I do have a question for you as you have replaced the b&o what-ever-it's-called connector with rca's. My b&o cables are junck. I have a phono input on my pre-amp, so I assume I'll just have to hook up the right and left channels and keep the ground? Can you post how you did it?
Martin,
Thank you also for your help.
- I plan on doing the caps last.
- The tachodisc is the metal kind.
- There doesn't seem to be any scraping or problem there.
- I did a quick look at the solder joints and other than some corrosian they seem fine - I'll remove the boards and use my magnifier/light to check for sure.
- Carriage seems to operate smoothly, what type of lube is best to use?
- Just replaced the little belt which helped a bunch.
While I was pulling it apart I noticed that the back panal connected to the dust cover and metal cover was more or less toast. Are there replacements available? I also need the mechanism that holds the dust cover up too.
I then started to "set up" the detector and pick-up arms per instructions which seemed to go well. I got to the point of setting the pick-up arm balancing and realized that I have no idea how to lower the pick-up arm. How do you do that?
Thank you again for your time and patience, I very much appreciate it.
ross
ps. boy do I miss spell-check!
