It's a hit and miss buying older B&O.
Any auction site avaible has the same pitfalls.
The tangial players are great when the work 100% right and looks good with no scratches etc.
The thing not to overlook is the electronic is at least 20 years old! This causes strange things to tangial players.
Just look through this forum for instance.
My Beogram 8002 were basically dead and if it was not for Dillen here it would not be working as new.
Another thing is when you do find a working one it will need service sooner or later if it never had anything done up till then.
For any Beogram this is the right place for finding help as the B&O shops cost to much, don't repair it right or won't have anything to do with it.
My Beogram experience began with 1203 radial player which played well. I still got it but the 8002 is working as the main player.
Then a radial 2000 (mid '80's)came up for sale and I went to have a look. It worked fine so I bought it. The next 3 years were faultless.
Since I had a BC9000 I decided to try to complete the 8000 system and found a lot of BM6000,BC8000 and BG8002 on a auction site.
The BG8002 arm moved 1-2 times and got stuck. Long story short I finally got Dillen to fix it and now it works 100% right.
In december I found a white edition system 6000 on Lauritz.com. It included a Beogram 6006 which had a nearly new original mmc20en on it. Slightly few faults and still celuid tacho disc! I managed to get it to play and the arm moves fine.
Tacho discs if celuid disingrate with time. These are found on Beogram 8000 and Beogram 6006 among others.
So if the speed is slipping the tacho disc is bad. Dillen has made reproduktions and its the only way to get hold one really.
My theory is that the older B&O stuff that comes up are mostly put up for sale since its not working or needs repairs.
