Hello again fellow Beoworlders.
I have just bought my second Beogram 4000. It worked good after a good clean, but it began to act strange after correcting the tracking weight.
When I press "on", the arm carriage will move about 0,5 cm and slowly move back to resting position. I can press the < which moves it towards the center of the platter but only in slow mode. I can press > and make it move faster towards resting position. I can't lower the arm anywhere. It basically works like the following scenario: It's like the > button is depressed a little (slow movement mode) which disables the arm lowering function. Could my fiddling with the tracking weight hurt anything?
For the record, I am used to 4000-series, have restorated 7 4002-4004 and 2 4000 with lubrication problems.
