2 Beograms connect to Beosound 9000
So the switch box arrived today.
Although I bought 'opened never used' from eBay, here's a reminder of the type from one of many suppliers:  link
I opened it up to check the wiring and it appears to be fully switching between all 5 pins of the din inputs (plus of course the added 'bonus' of the 15-pin VGA sockets).  I think the main rotary switch would be described as at least 20-pole two-way, but I may well have the terminology wrong!
Anyway, I did a quick check with a couple of iPhones and it works well to switch between two-5 pin DIN inputs to a single 5-pin DIN output.  It comes in a nice metal case with rubber feet.
Here are some photos:
I did check for 'crosstalk' between the two inputs but couldn't detect anything.  I am not sure that I would use it for non-RIAA/pre-amplified turntables due to lack of screened cables, but as a line-level audio switching box I would expect it to be fine - hence perfect for connecting two turntables to the BS9000 as asked in the thread.  You would just have to remove pins 6 and 7 from the Beogram DIN plugs, and then use a 5-pin DIN to DIN for the output/input to BS9000.
It would also be quite easy to replace the 5-pin sockets with 7-pin for datalink (or 8-pin for Powerlink) and move some of the cables from the VGA sockets.
Happy to answer any further questions!
Hi, Much appreciate for your detailed information and pictures. I will consider to take your advice to solve my issue. Many thanks! ?
Hi Guy,
Looks like a very interesting and well made project, thanks for sharing this!
Kind regards, Steve.
