BeoCom 5 + BeoLine 2
I purchased a used BeoCom 5 + BeoLine 2 here in Switzerland. The seller says it was working fine until they unplugged it to send it to me nevertheless I'm unable to register the BeoCom 5 on the BeoLine 2 base. I unplug and plug the power of the BeoLine 2 base so the base is open as the front led starts blinking. Then on the BeoCom 5 I select the menu option "Settings > Handset > Register" and the phone display shows the message "Searching base Wait..." forever. I perfectly find the base using a Beocom 6000 though. I checked the BeoCom software version and it is 2.43 from Feb 2013. Any idea how to be able to connect the phone to the base? Do you think the phone might be damaged?
Hi and welcome to Beoworld! Maybe try resetting the base using the connected Beocom 6000.  Perhaps it has too many phones registered to it. Assuming the Beocom 6000 is a Mk2 (with an INT button) enter the sequence 9#9#9* and press INT.  Use the scroll wheel and choose reset base. EDIT:  I think you can also reset the Beocom 5 using the same 9#9#9*INT sequence.
Guy thank you for the reply. Unfortunately I only have Beocom 6000 Mk1 so no INT button. A simple reset button on the base as any other manufacturer in the world does would have been great. I'm totally blocked if in order to reset the base I need to have a Beocom 5 registered on the base.
I tried "Dot 70008" and the message below was shown on the Beocom 6000 screen:   PHONE BOOK ** NOT BASE 1 **   Then I tried to register the Beocom 5 on the base but with the same result "Searching base Wait..."
I forgot to say that after pressing Dot 7 000 8 you should press OK (centre of wheel). Does that make any difference?
If I press "Dot 7 000 8" then after 4 seconds it goes to the main screen where the current time and date are displayed. If I press "Dot 7 000 8 Ok" then it goes to the main screen where the current time and date are displayed. Pressing Ok at the end just makes it directly jump to the main screen where the current time and date are displayed instead of waiting for the 4 secs timeout. I'm sure the Beocom 6000 is connected to the Beoline base since I can make phone calls successfully.
I just tried the option "REMOVE HANDSET" on the Beocom 6000 and I get the same message on the screen: PHONE BOOK ** NOT BASE 1 ** According to the manual this message means "The Phonebook is stored in base 1, but base 1 is inaccessible." It is really weird since the Beocom 6000 still can make phone calls so the base 1 must be accessible being the only base registered on the phone. In summary it is not an specific problem with the command to reset the base since this other command fails as well.
I presume that the BC6000 was originally connected to another base that you own, known to it as 'Base 1' (with your phonebook stored). If this is the case, your phone still has registration to 'Base 1' stored - even though it is currently connected to a different base (Beoline 2) to make calls. Perhaps the BC6000 can only reset the first base that it is connected to, and this is not currently the Beoline. You could try resetting the BC6000 handset: Dot 7 000 9 OK. Then re-register the BC6000 to the Beoline 2 and try the Dot 7 000 8 OK trick to reset the Beoline 2. However, I do know that there are software incompatibilities between older handsets and newer bases, so perhaps you simply cannot reset a Beoline 2 from a Mk1 BC6000. I can't think of any other suggestions, apart from disconnecting everything (perhaps even removing phone batteries), leaving it overnight and trying again tomorrow. Beocom/Beoline registration can be quite temperamental and sometimes it takes a bit of patience and luck!
I tried everything you suggested but nothing worked. I'm going to try to return the phone to the seller. Thank you!
