anyone know how I can check whether either my BC2 DVD or BC2 DAB can handle DAB+ - both are OK with DAB.
Beocentre 2 DAB+
It would seem hard to see for sure whether a BC2 has the DAB+ upgrade - if you search second hand ones for sale there is sometimes an annotation of the label to say that the DAB+ module has been added.
This thread from the old forum may be useful, if only to rule out DAB+ fitment due to serial number incompatibility: /forum/general-discussion-and-questions/beocenter-2-and-dab#post-1981149
I assume that you are in UK where there are not many DAB+ stations anyway.
There was a concerning article in The Telegraph which said that stations would be moving to DAB+ in the UK (classic FM will do in January) although the BBC said they will support DAB for the foreseeable.
bit annoying that a DAB+ upgrade would cost about £700.
I meant to add that you could also look at one of the OneRemote products to get DAB+ on your BC2.
DAB+ radio options here:
Thanks - I’m using ML and NL, so I doubt that these will help. I suspect that while DAB is still being used in the UK, I’m OK for now.
