Beocenter 7700 - Compatible with DAB+/Internetradio?
Dear Community, I inherited a Beocenter 7700 from my grandfather and would like to upgrade it to a DAB+/Internet radio using a Digitradio TechniSat 11 IR. However, I couldn't find an AUX input and I'm unsure how to connect the Digitradio (I have already purchased a DIN adapter). Is there a solution for this? Or is there no way to add an input to the Beocenter 7700? Thank you very much for your help!
Hi Fabienne Use the tape 2 rca inputs (marked play) on the back and the TP2 setting. Gordon
GLMobbs
Thank you Gordon. I can‘t find a input marked „play“ though. Is it one of the four on the right? I tried to use the one with the grey blind plug as a DIN connection, but it probably is an output not an input?
Attachments (1)
The grey plug/socket is a loop through which enables you to add external tone control - it is of no use here and the grey plug should be inserted for the unit to play correctly. The Tape 2 'line in' phono/cinch/rca sockets are the next two along - left and then right.  They should be labelled on the rear edge (behind the connection in your picture).
