XML generator tool
Quim43 wrote:
Have you tested the xml file making a new configuration or just modifying an old one?
It happened to me, I just modified an old configuration and the new commands didn't overwrite the older ones.
Try to begin from zero, to see if the xml file works on your TV
Good luck
Have tried both. Nothing seems to work😜
The best course of action is to get a IR capture product or a Lintronic box then you know for sure you have the correct infra-red codes. After reading further about Pioneers codes its clear they change the codes for almost every product by giving it a different address code, so finding someone with a Pioneer TV almost certainly will not provide you with a solution.
I am however pretty sure that the codes I sent you are correct. I got an excel file from Pioneer in denmark with the ir commands as I wrote in my previous post and matched these with the codes online. Isn't this ok to do?
Further, does it have to be a lintronic box? Can it not be a philips learning remote?
What do you mean by the statement:-
You said "and matched with the codes online"
The Pronto codes you provided were translated into an NEC protocol which was then added to the XML file in RAW format meaning the infra-red code produced is the exact copy of what would be produced using a Pronto
You don't need a Lintronic box, anything which captures the infra-red is fine, but using the Lintronic box means you can take the captured code and provide it directly to the XML Generator which if you are using the XML Generator you would know.
I realise this part was not very well written.
Here we go: In the file I sent you there are 4 collumns. One with a category, description,commannd and pronto code. I wrote Pioneer here in denmark and they sent me a complete list of commands for my exact model. In the file they sent were only the commands(for example AA1C for toggle on/off). I took these commands and looked at the file I sent you and saw that they were identical and figured that, this would also mean that the hex code in the file I sent you would be the correct ones. Make sense? And is this assumption correct?
Whilst the command for toggle on/off may be AA1C there is also 128 possible product addresses from 0 to 127, so you can have the right command code, but not the correct address. In the file you sent me there was no product address.
Ok, you lost me.. Product address? And can i manually go through them and find out which one?
The file from Pioneer Denmark does not contain any address either. Only the code list for my screen (like AA1C)
Let me explain in much greater detail.
We have established that your Pioneer screen uses NEC protocol and that the carrier frequency used is 40 Khz and the commands in the file you sent to me from Pioneer are for your screen. I said what about the product address ?
With the NEC protocol, the product address can be in one of two forms, standard addressing ( 8 bit addressing ) and extended addressing ( 16 bit addressing) 16 bit addressing provides 65,000 different addresses and 8 bit addressing provides 256 addresses. I previously said that it provided 128 possible addresses, but that was an error on my part, I was 1 bit out, it is 256, 0 to 255
The actual infra-red protocol transmission is in the form as below:-
The above diagram shows standard addressing where you have the address followed by the address inverted.
With the extended address there is no inverted address and all 16 bits make up the full address.
It is likely that Pioneer are using extended addressing because most manufacturers do today because a lot of users have  products from many companies in their setup and they want to be sure which product is being addressed.
So, if they are using extended addressing then there is 65,000 possible different addresses, so as previously stated you only have two ways to find the product address:-
  1. Ask Pioneer what it is remembering they will use a different address for each Pioneer product
  2. Capture one command from your remote and decode the address
The reason we provide the XML Generator to convert from the Lintronic timings is that we don't have to decode each NEC protocol and find its address which would take a lot of work.
thanks for the info.  Really helpfull.
Still don't quite understand why this is concerning this Pioneer product when it doesn't affect my squeezebox for example.
And if this Product Address is important why isn't it incorporated in the code I got? And where do I plot it in if I can get it?
I have a friend who has a Philips remote and the same tv. I will get him to try and learn a couple of codes. Where does he see what the product address is?
