XML generator tool
eljefe wrote:
It is for use with the KRP500A model.
Are the codes right? Or what else is wrong?
You did not answer my questions. There are different codes for different Pioneer products and unless you know what protocol was used for your product then the only way to determine the correct ones is trial and error or capture the codes and decode them.
Given your pioneer product is a Plasma TV, so fairly up to date, then I got the latest Pioneer plasma Proto codes and converted two of them, i.e. power off and power on for you to test. You can download the test XML file
Given your pioneer product is a Plasma TV, so fairly up to date, then I got the latest Pioneer plasma Proto codes and converted two of them, i.e. power off and power on for you to test. You can download the test XML file link
Hi Keith
What didn't I answer?
Anyway, thank you very much for the test file. Sadly it doesn't work. Pioneer must have switched codes for the new screens which is quite strange. I haven't been able to find the codes anywhere and I don't have a device that is able to learn the codes. Is there any other way?
Again, thanks for your help
I think you answered my question in the last part of your last post where you said you do not have a device to capture the codes.
I suggest you either find someone near you with a Lintronic or other capture product or you could send you remote to me and I will capture the codes. Where are you located ?
As great an offer as that is I think it would be quite difficult as I am in Denmark.
I found this database
I think the reason you have not found your model in their list is because KRP500A is a package of screen and media box and not the screen model number. Think think you need to look for the screen model number.
Hi Keith
Thanks for the welcome.
I have the Lintronic box and it is working quite well.
But the problem with volume up and down is killing me.
I want smooth volume changing and would rather be using the BEO5 itself.
Are there any manual for the XML generator or can i use the Lintronic files as provided in earlier post ?
Do i need to write other Lintronic files to parse the XML generator ?
It would however be great if i could use the decoded Lintronic files as they are.
It is also a quite large databse of ir codes that are present in Lintronic codes...
I tried getting hold of a pronto ccf file, but i just cant se how to use it in XML generator.
Thanks for adwice
Regards
Jacob Just
Hello Jacob
You can download the help file from
Hi keith
I am one step closer i think. I now have an excel file containing the correct IR codes. And I crossed these with another file containg both IR and HEX codes so I can now confirm which codes are for my screen.
This however still does not solve my problem. I am really confused. I changed the carrier in the file to 38000 and even tried a couple of other carrier frequencies but ultimately it didn't help. Any idea to what my problem might be? I can't understand why it is so complicated for this product.
If you upload the file in a zip file you have found
I have been trying to do a bit of research on the subject and it seems that the Pioneer Elite models are using high frequencies as carrier so I suspect this to be the problem. I can't however find out what this frequency is
