I have them converted into text files via. the lintronic software. Ill have a look at the files. Please let me know if you have any other tips.
You can proceed with these files and the V1.0 of the XML Generator tool. With the final XML have a look at the examples. Threre seems to be very little difference (in the case of my file the only difference I found is the Carrier, which is 38000 instead of 38), however one user reported that changing only this, did not work for him. For the usage of the hard buttons I was looking at one of the other examples to see how it works and copied the converted Pioneer codes.
Cheers,
Frank
