Hey Keith
Lintronic had a Software- Update and is now displaying the Output Box of "High/Low" as follow:
Pulse, Pause in micro-seconds
03576 ( 271 ) 01627 ( 123 ) = 5203 ( 394 )
00531 ( 41 ) 00341 ( 25 ) = 872 ( 66 )
00532 ( 41 ) 01218 ( 93 ) = 1750 ( 134 )
00532 ( 41 ) 00344 ( 27 ) = 876 ( 68 )
00531 ( 41 ) 00342 ( 25 ) = 873 ( 66 )
00533 ( 41 ) 00342 ( 25 ) = 875 ( 66 )
00532 ( 41 ) 00341 ( 25 ) = 873 ( 66 )
00532 ( 41 ) 00342 ( 25 ) = 874 ( 66 )
00531 ( 41 ) 00343 ( 27 ) = 874 ( 68 )
00530 ( 41 ) 00341 ( 25 ) = 871 ( 66 )
00532 ( 41 ) 01220 ( 93 ) = 1752 ( 134 )
00531 ( 41 ) 01219 ( 93 ) = 1750 ( 134 )
00532 ( 41 ) 00343 ( 27 ) = 875 ( 68 )
00530 ( 41 ) 00343 ( 27 ) = 873 ( 68 )
00530 ( 41 ) 01218 ( 93 ) = 1748 ( 134 )
00532 ( 41 ) 01219 ( 93 ) = 1751 ( 134 )
00531 ( 41 ) 00344 ( 27 ) = 875 ( 68 )
00531 ( 41 ) 01218 ( 93 ) = 1749 ( 134 )
00530 ( 41 ) 01220 ( 93 ) = 1750 ( 134 )
00531 ( 41 ) 01220 ( 93 ) = 1751 ( 134 )
00530 ( 41 ) 08881 ( 675 ) = 9411 ( 716 )
As you can see, the Format changed totaly. The XML Generator will still create the File, but you wont be able to Serialize it in the Beo5 Tool.
