hi everyone,
it would make me happy, if anybody has the xml-file of this fan.
greetings...
hi everyone,
greetings...
You will need to capture the IR codes or find then in Pronto HEX format so I can convert them for you.
thanx for your support keith, buth this is exactly my problem: i cant't find pronto codes for this device on the web and have no opportunity to capture the signals (no lintronic). converting would be the a minor problem because of your excellent software 😕
Do you know that you can actually ask your dealer to request this device for the Beo5 Configuration Tool?
Your dealer must contact his local PUC representative with the request.
The decoding service is for free (except for shipping cost), but your dealer may charge you for programming your Beo5.
